TwinTurbo.NET: Nissan 300ZX forum - Is the 'Gang Point' Ground hookedup at the back of the Penum (n/m)
Cjw3
on September 03, 2018 at 7:04 PM
TT won't idle at same time as brake, and stop/tail warning
posted by Vert93 (MN)
on September 03, 2018 at 05:18 PM
Vert93 (MN)
17:18:20 09/03/18
Is the 'Gang Point' Ground hookedup at the back of the Penum (n/m) -
Cjw3
19:04:28 09/03/18
There are 2 grounds hooked up on the back of the plenum.
Vert93 (MN)
20:57:00 09/03/18
Re: There are 2 grounds hooked up on the back of the plenum.
Metacom
22:38:46 09/04/18
Can you explain more on what happens when it "wont idle"?
Polish
12:21:55 09/04/18
It will just barely run @ about 550 rpm. And within seconds,
Vert93 (MN)
17:54:57 09/04/18
Re: It will just barely run @ about 550 rpm. And within seconds,
TheKryptKeeper
21:53:34 09/04/18
Sounds like...
GrecV2
06:47:10 09/05/18
Idle is now good. Brake lights come on during acceleration.
Vert93 (MN)
18:31:23 09/15/18
Have you verified that the TPS is set correctly? (n/m)
CarolinaZ_TT
07:09:07 09/06/18
Re: Have you verified that the TPS is set correctly?
Vert93 (MN)
18:33:59 09/15/18
